Table
(ltp) #1
So i found a small circular table being disposed of recently.
The top was chipboard / melamine and it was rubbish. So i threw that out and kept the base.
Then i decided to make a new table top.
So I cut down some reclaimed timber.
Planned them all to the same thickness
then Glued them up.
New photo by Craig Hudson-Taylor
Then I decided to Burn it using electricity (Lichtenberg Figures)
Thanks to Eris for the Transformer and @AdamBinns238 for the help.
Setting up.
Starting to burn (Use Alkaline water as medium (mix in Baking Soda))
https://photos.app.goo.gl/9wz7jwsHeEn6FsYv1
https://photos.app.goo.gl/8MLyuQovfacQJvDf1
Good coverage
Cleaned up and washed down
Made some bracing to add some strength and thickness to mount the base.
Cutting the Circle using a router
Gluing the bracing
I drilled some holes and mounted some nuts into the bracing.
Put it together for the first time
Filling burn holes with Epoxy
Colour is Interference Blue
Tape up holes and edges
Fill with epoxy
(Buzz) #2
Looks amazing! Love to see the finished result.
(ltp) #3
So using a Hot air gun and a scraper I took off the excess epoxy
Then I have sanded it down (still needs some more to finish it)
(Johannes) #4
Coolest table I’ve seen in a long time.
(ltp) #5
So I decided to just round the edge with a router.
New photo by Craig Hudson-Taylor New photo by Craig Hudson-Taylor
Had a couple of failures occur as the timber was a bit unforgiving
Tidied up underneath
Finishing up
Actually filled some holes with a bit of putty and or sawdust.
Filled up a bunch of cracks in the Wider band. the wood was very old and dry. So before I Finished it i filled up a lot of the cracks with Glue. Should help hold it together and is invisible.
Fixed up the issues with the router
Not entirely happy, but I dont have the time to do any better atm. Maybe I will modify this in the future to fix it. (not sure the best way yet. This will make it functional.
Actually mixed some of the same timber sawdust into some putty to try to get a better colour match.
is still pretty obvious though
Basically the final product (put a couple more coats on after this).
Lightning really pops
Mounted it to the base and is all good.
(ltp) #6
I took some photos of it drying with the final coat
(Jacques) #7
It is magnificent. Well done.
(Ian Redmond) #8
Very, very, nice!
(Dylan) #9
Well done mate, looks fantastic
