3D printer for sale - RepRapPro Mendel 3 - $300
Hey all,
I’m selling my RepRapPro Mendel 3, as I don’t have enough time for it anymore.
I bought it back in April 2015 with the HackerSpace Kickstarter for about $760.
I would like $300 but price is negotiable.
TLDR:
  • 3d Printer (working but not calibrated)
  • Flexs3d Buildplates
  • spare Nozzles (0.5 mm and 0.3 mm)and Heating block
Photos: https://photos.app.goo.gl/mrYnmGsCzwrKPB3U9
Pickups are possible from: HSBNE, Milton (only Tue, Wed) or Hawthorne
longer version:
3D printer RepRapPro Mendel 3 (bought April 2015 for AU$756)
Features
  • Fully open-source self-replicating Cartesian RepRap kit
  • 32-bit Arduino-compatible, shielded Duet electronics enable control via a web-browser
  • Pre-soldered Duet board with a built-in micro-SD card for standalone printing
  • Wiring looms for simple plug-in connection – no soldering required
  • Non-contact Z probe for automated bed plane compensation
  • RepRapPro Quick-set hot end
Specifications
  • Build volume: 210x190x140mm
  • Overall size: 500x460x410mm
  • Printing materials: ABS, PLA, 1.75mm diameter thermoplastic.
  • Build surface: PCB-heated bed to reduce complexity of assembly and to ensure parts do not warp.
    – Computer interface: USB, Ethernet
    – X-carriage: Three Z-adjustable deposition head mounts; one head supplied.
  • Standard nozzle size: 0.5mm
  • Accuracy: 0.1mm
  • Resolution: 0.0125mm
  • Building speed: 1,800 mm/min
  • Moving speed: 12,000 mm/min
  • Deposition rate: 33 cm3 / hr
KIT: https://web.archive.org/web/20160814005531/https://reprappro.com/shop/reprap-kits/mendel-3-full-kit/
Docu: https://web.archive.org/web/20160318171537/https://reprappro.com/documentation/mendel-3/
FLEKS3D Simple 8"x8" (203x203mm) build-plate. (~AU$45)
Spare Nozzles and heater block:
Quickset nozzle Diameter: 0.5mm
Quickset nozzle Diameter: 0.3mm
Quick-set heater block
(AU$36)
Let me know if you are interested.
(also advertised elsewhere)
Cheers,
Alex
