Big ass lathe
Cheer @rut4ger for installing the micros.
Still wont start in normal operation, can dodge it working, but still no luck.
@Thermoelectric do you have any ideas, I followed your cheat sheet to no avail. It dosnt seem to want to bring in the latching relay.
I’ll probably be in today, will have a look then. Is the jumper still on the foot brake switch? AFAIK that’s the only switch that was giving me grief.
It is
Fixed it. For the record, one of the motor overloads tripped. It was set to 6a, I’ve upped it to 7a as that’s what the other is. Shifting from forward to reverse while it’s still spinning may cause this but I couldn’t recreate the problem.
You are a ****** legand
could we please look at getting the power cable for it properly spliced and run to be made safe ASAP.
what i saw yesterday scared me a little bit.
Honestly I’m not worried until it starts to becomes a tool rather than something we are fixing, but the issue is the only 3 phase cord we have that’s long enough is massively overrated, making it heavy and really inflexible. However your concerns are noted, and this is something everyone working on the machine was already aware needs changing before we would mark the device as safe for work.
Thanks for letting us know, will sort something out asap
Absolutely man, it was never intended as a permanant solution, just a temporary solution for testing and repairs to see whether its worth spending money on. Its not close to a usable state yet, still doesn’t have a fully functional brake yet and needs some Big Red Buttons and swipe access on it before its fit for service.
I understand that it was a temp solution i was concerned that at the time i saw it they’re was no one in the metal shop but me.
Tbh. Even putting that same join in a junction box no one would ever know. Lol
Already done, put it in a junction box after you guys saw it on the weekend.
Legend…
So, this lathe has seen a bit of an upgrade electrically since this topic was posted.
I’ve since added a VFD to replace the original start gear, and a power switch to the front. Still gotta put it back together completely, wire that power switch in, and put a new plug on it.
As a result of the VFD it brakes electronically whenever it is stopped/brake depressed/taken out of drive. This slows it down a lot quicker than it would otherwise, and is most noticeable on the highest gearing. One thing to note is this dumps a lot of power into a small resistor, so try not to go start and stop the highest speed too often.
It’s been brought up occasionally that we should sell this lathe as it’s non functional, this is incorrect. It works fine, however has some gearbox quirks. Definitely worth considering keeping for larger stuff if we clean it up.
Can you hazard a guess at an ideal wattage and value for that braking resistor? I can probably make you something suitable out of bits I have kicking around.
