If I wanted to remove a series of angles from a flat piece of material (think like a sawtooth roof) with all the angles diffrent. How accurate an angle can I make with the tools in the metalshop?
Fairly, depending on the surface finish and what material it was.
If I recall my calculations correctly it was in the sub-degree area that I needed.
A drawing would go a fair way in figuring out what you’re trying to achieve there. I can’t really tell the possibility without knowing what you’re doing.
