Collaborative Project- Swords
Every year I run a big strongman competition, and as part of this athletes have the chance of taking out a series of competitions I run at different gyms through out the year.
First year @Wixted helped me with making some cast aluminium bronze hammers (slightly smaller and more-gold version of this)
Last year I made some hand-carved axes:
So, logically, this year I have to make swords :sweat_smile:
I need to make somewhere between 5-8 of them, they can’t cost a horrendous amount ($30-$50 each would be great) and can’t be too time consuming. I’ve had a few ideas of how I could easily achieve this, but always open to suggestions.
I don’t have the time to forge 8 full swords, so I would be getting a large proportion of each one laser cut.
Thoughts?
There’s a few different types of sword that come to mind, (I’ve done longsword and rapier) but if you want something simple and obviously sword-y, I’d suggest a roman gladius, as it’s a fairly easy shape, and you could make either wood or leather stacking for the handle. The guard and pommel can be made from the same stuff, but might take a bit of time for carving.
Another idea, for something even simpler, is a dussack, there are forms that are very simple and made in one piece, but you do have the option of adding fancy handguards if you wish.
Also, may I suggest tridents for next year? :stuck_out_tongue:
I should probably add one thing - I think these probably have to be metal :sweat_smile:
Whaaaaaat? No!
In that case, dussack is probably the easier bet for one cut and done- https://commons.m.wikimedia.org/wiki/File:Dussack.jpg
I’ve gone a totally different route, and want to have as much of this fabricated for me as possible. The handle will be wrapped with something, however this is the sort of style I think will be quick and easy.
I think I will have to add something decorative across the guard as it’s a bit simple for me at this stage
