Hello All,
Migrating the ongoing WIFI User network dissussion off list into here:
^ Reference for the kind of tech we have in mind
https://mapsengine.google.com/map/u/0/edit?mid=zB7RwUJPuymA.kn6UbCkfqaRM
Current Node Map.
http://www.zcg.com.au/fireco_maxi_primo_mast.htm
Possible Mast to use for people who want to put it up and down easily.
when do I need a building permit…?
http://www.metrobs.com.au/build_perm_when.html
MASTS/ANTENNAS
HEIGHT MORE THAN 3M ABOVE THE HIGHEST POINT OF A BUILDING (IF ATTACHED TO A BUILDING) YES
HEIGHT MORE THAN 8M ABOVE THE GROUND (IF NOT ATTACHED TO A BUILDING) YES
Current Blockers:
No enough LOS to high places.
Hill’s
This hardware is realtivly cheap, and gets crazy range.
http://nodedb.wafreenet.org/nodes/163/possible_links
I have also put most of the nodes on the map in (I’m still adding them at this point).
If you have access to a parents house or other area with good LOS to places, add it in and see what you can come up with.
This is from WA Freenet which is the equivilent to what we want todo. they have very genersouly said we can use this to plan.
it does all the elevation and obstruction calculations. woo!.
that’s all for now.
All current nodes are in.
Next step:
See who can see who!
http://nodedb.wafreenet.org/nodes/153/possible_links <— this be your starting point, its the HSBNE Porthack node, if you can see a redline thats not obstructed between you and HSBNE GRATS!
otherwise, click your name, then click the “possible links” link.
http://www.ubnt.com/airmax#nanobeam for anything up to 20km, i have it on good authority these are the go.
https://www.wisp.net.au/advanced_search_result.php?search_in_description=0&keywords=nano+beam&x=0&y=0
possible supplier.
for anything longer, we can use the airgrid. its good for 60kms.
theban
(Brendan Carmichael)
8 May 2014 04:39
4
Thanks for setting that up & the info. Are we going to standardise on 2.4GHz or 5GHz? I assume there’s less congestion on 5GHz.
We will use both.
However, in busy placed we will have 5ghz for backbone and 2.4ghz for distro
pikkaachu
(pikkaachu)
25 October 2014 11:38
6
Bump.
Still working on this. have now got some sites scouted out.
Who’s still interested?
Cheers
Ben
Blufires
(James Beecham)
2 November 2014 02:43
7
I’m on the corner of Sandgate Rd & Adelaide St in Clayfield. Sadly I have no money to buy equipmunks but if anybody wants to install one at my house that would be fine. I’m at the top of a hill so range should be good.
merseyless
(Blair Calderara)
5 November 2014 04:50
8
How much will each node cost and what capabilities will it give? Are we sharing internet or doing up one big network of filesharing?
pikkaachu
(pikkaachu)
15 November 2014 06:17
9
Merseyless, you can do both and more, you can setup internal services.
Each node costs depends on what gear you want to install.
Ie. down south one guy build a tower with 5 radios. (thread i linked) Which cost $550 total, including the hire for the skyreach platform.
Hey All,
Still been punting away at this. Have gained access to mt cootha and to a few other buildings around the place.
Have also setup a new channel on the HSBNE Slack team #qfi for anyone interested in being involved in the network!
Any interested drop some details here and we will start mapping out nodes.
I have ordered some gear for testing and and what not.
