Hi all,
Just letting you all know that the herringbone gear on Alan’s printer has borked.
As such, we no longer have any functioning printers at the HSBNE.
I will bring in a spare gear from my printer and see if I can print a few spares in case this happens again.
Ah shoot, I’ve already installed the replacements and printed out a few parts.
The firmware will need reflashing though as the gears are of a different ratio, but I don’t think this design will fail for a while.
Thx for sorting out the issues so quickly. As a secondary note why’d you decide to go with a 3 poke design? I’d have though that something more like 12 would give wore even flex\support to the gear face…
I almost got one of the other space printers (in the laser cutter room) working last night. It’s essentially ok but the heating up is a bit flaky… the plug leading to the hot end is sus …wiggling it make the heating better/worse … and when trying to heat the heated bed and nozzle at the same time the power supply struggles badly.
It needs a good PC power supply preferably 400w or more, and maybe solder the dodgy connector up.
I think that’s essentially it.
As far as I know, only my printer is working, and you will need pronterface to interface with it.
Chang Yi informed me that there should be multiple hot ends available at the space. I will head over there tonight to install a new head and extruder motor driver
