Kitchen Bench Build
I am working on a Custom Kitchen bench for my place.
Pretty basic plans, the top will be about 1200 mm long and 800 mm wide and around 50 mm thick butchers block top (all endgrain).
One side will have an overhand for a breakfast bar and one end will have rounded corners.
Under this are two shelves (stainless steel)
I also have plans to integrate a bowl system to easily pickup food after cutting it up.
And a knife block for easy access.
Started by cleaning up and cutting some recycled timber I had (all from 1 piece of timber)
Google Photos
Four legs, six short and six long cross beams.
To join the legs and cross beams I am using a mitred cross joint (I think that is what it is called)
Google Photos
Google Photos
Google Photos
I cut the joints on the table saw using the crosscut sled and cleaned them up with a chisel
Google Photos
Base goes together like this
Google Photos
The aim is to pin these also with through dowels
so I main a dowel maker and then a bunch of dowels
Google Photos
Google Photos
Google Photos
I made a jig to drill all of the dowel holes
Google Photos
Google Photos
(still need to do the cross beams)
onto the Top
its going to be made out of a random assortment of scrap or recycled hardwood
Google Photos
which basically involved me cutting up lots of timber and gluing them all up.
Google Photos
then cutting them up more, then gluing them back together
(with a bunch of repair when a bunch of them didnt glue up as well0
Google Photos
current pile looks like this
Google Photos
I have more I am fixing and more to cut up still
Here is some more scrap I have glues up
Google Photos
I ran them over the planner and through the thicknesser to square them all up and clean off all the glue
Then I cut them into 55 mm lengths
Google Photos
Glue ups were better this time… but still come need to be fixed
Here is a rough idea off how it will look when it is all randomised.
Google Photos
I still only have about half of what i need (it is a big bench top)
so more timber to cut up and glue
Making more pieces for the bench top
Google Photos
Using the new joinery blade I cut slots in the cross beams
Google Photos
Google Photos
Google Photos
base goes together like this
Google Photos
So had some delays and issues with some of my top glue ups…
so up to this point I made this much of the top… Is only about 2/3 of what i need
Google Photos
so Glued up some more timber
Google Photos
using the new pipe clamps
So i think I have enough now
Google Photos
So i started gluing up some of the blocks a while ago
here I did some more
Google Photos
So making progress on the top.
I glued together most of the pieces into blocks then laid out the blocks in a rough plan.
Needed to add some more bits to some and make an extra block.
From there I used the planner to flatten one side and squared off all the sides on the table saw
Google Photos
then to get the other side flat, I trimmed one edge on the table saw before putting them through the thicknesser. This was to stop tear-out on the trailing edge. This worked pretty well as long as i didnt take it down all the way.
making progress
Google Photos
Then I started gluing up the blocks into the cross strips. I used dowels to keep them flat and add a bit more lateral strength.
Google Photos
Now I am dowelling up the cross strips
Google Photos
and thats as far as I got today.
So I Put the top together.
Google Photos
Google Photos
After a bit of sanding I put a bit of metho on to see how it would look
Google Photos
Google Photos
Next I started to work on the frame…
I put the dowels in the legs
Google Photos
Google Photos
This was actually a mistake as it was harder to put the legs together and I damaged the cross beams.
got some chipout which I had to glue up.
Google Photos
So i put the ends together first and glued them up
Google Photos
Google Photos
Google Photos
Then I glued the ends using the main cross beams
Google Photos
Google Photos
Google Photos
SO then I trimmed down the top
Google Photos
had a bunch of issues getting it straight so I ended up with a smaller top than i planned…
Then I added all the cross pieces
Google Photos
Google Photos
then i put the top on to see how it fit
Google Photos
Google Photos
so this is because the top is not as wide as planned
Google Photos
Then I rounded off the end corners
Google Photos
Google Photos
Then I glued on the back pieces
Google Photos
Then I rounded over a lot of the edges with a router
Google Photos
Google Photos
I rounded over a lot of the edges in the frame as well
Added some screw ins to the top to bolt the top to the base
Google Photos
Google Photos
so one of the features i wanted to build is a feature into the table… an easier way to put the food into a bowl.
so I cut a hole in the top…
Google Photos
Google Photos
I built a shelf that goes underneath
Google Photos
Google Photos
it goes like this,
Google Photos
Google Photos
Google Photos
so then… Sanding… sanding and more sanding…
finished the top… time to oil it up
Google Photos
Google Photos
Also I drilled some holes in the legs for the feet (I decided to do this to make it easier to level and make it flush against the current benches)
Google Photos
had to cut off the screw in’s as the feet wouldnt even screw into them
Google Photos
Google Photos
so I also have some stainless shelves and a plug for the hole in the top being made…
So basically I finished all the timber portion of the bench.
I used a wipe on poleurethane on the base and shelf.
Google Photos
Google Photos
Google Photos
Google Photos
Google Photos
Google Photos
So in my apartment now.
Still need to make the shelves and a plug for the hole.
