devians
(Josh Hogendorn)
16 November 2020 04:08
1
A few members have raised concerns about having advanced safety interlocks for big cnc machines such as the YAG and the new sheet cnc router. I don’t have time to pursue this but I’ve done some basic research and please find the links below for further discussion:
CNC Machine Safety – Lowell Corporation
At Lowell using CNC machines is part of the daily routine, but it is extremely important that everyone remembers the proper safety rules while operating the machines.
Est. reading time: 2 minutes
The Three Types of Safety Hazards in CNC Machine Shops
wcms_164653.pdf
Heavy-Duty, Pressure-Sensitive, Laminate Safety Mats
Heavy-Duty, Pressure-Sensitive, Laminate Safety Mats require weight to be applied for the machine to operate, and are active over the entire surface area.
Price: USD 620.0000
Safety Floor Mats - Sensor Measurement
Fiessler Safety Pressure Mats and Switch gear correspond to the following safety regulations: IEC 61508, ISO 13849-1, EN 954-1 Safety Contact Mats are used for safeguarding areas of danger on machines and plants with the aim of preventing unchecked...
Safety Light Curtain Australia - Sensor Measurement
Safety Light Beams - Sensor Measurement
Manufactured to Standard EN 954-1, IEC 61508, ISO 13849-1 Areas of application: Presses for metal, wood, plastic, rubber, leather and glass Filter presses Chamfering and bending machines Injection molding machines Machining centres and welding...
Omron Light Curtain
http://www.omron-ap.com/solutions/auto/safety-light-curtain/solution.asp
Safety Contact Edges - Safety Bumpers - Grainger Industrial Supply
