Motor Mounting
I have a motor that I would like to mount the axle too.
Does any one have any ideas on how to do so?
cog set, pulley+belt, hotglue, shaft coupler, depends , what are you trying to do?
I am trying to build model robotic legs. This is the top of the lower leg.
that still doesn’t tell me what sort of mechanical connecton u are trying to make to the motor…? maybe this will help tho. https://www.google.com.au/search?q=shaft+coupler&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi95PSK_PDSAhVIoJQKHeAhB28Q_AUICCgB&biw=1263&bih=793
I have another aluminium arm like the one in the image which I want to connect.
