Still doesn’t help if your parts on the Schematic aren’t labeled.
Where is the power in?
Which connector goes to the MPU?
Is that a SCL line?
Etc…
Label everything it helps to reduce dumb mistakes.
If you need some help with best practices look up some of the sparkfun boards or drag me aside on tuesday
Hi…i am a new user here. I am attempting to characterise the MPU-6050 as a first step towards robust calibration. Part of this is achieved by logging the gyroscope zero-rate output over -20˚C to +70˚C. All investigations are conducted for a batch of 8 devices.Results suggest that the bias temperature relationship incorporates a hysteresis. This behaviour is observed for all tested devices. Other temperature sensitive devices monitored during these tests do not display this behaviour.
Hi LulaNord, I am not a new user here. I am attempting to characterise spambots. Part of this is achieved by googling exact phrases posted by new users that meet certain criteria.
1, First post is necromancy
2, Subject matter is only slightly on-topic
3, Post would have been better off as new thread
4, Text reads as though it has been cut and pasted from original sources by someone who English is not their mother tongue.
If you are not a spam bot herder you are in luck because there is a thread on the sparkfun forums from 2012 that will have all the information you need
