Needlessly complicated deep freezer repair
A while ago some water got where water shouldn’t and my deep freezer went ka-bang. Now with an ESP8266, a DS18B20 and a relay to switch the compressor, BAM:
Marvellous!
I hit submit too early, and I can’t work out how to edit posts.
The ESP8266 is a Wemos D1 Mini knockoff, basically an ESP-12E breakout board w/ TTL serial converter. It’s running micropython. It connects to my wifi, then my cloud server running mosquitto, mqttwarn, influxdb and grafana.
I can adjust the setpoint, hysteresis and minimum compressor off time via retained MQTT topics on my server. It publishes food compartment temperature and compressor temperature every minute. I could probably reduce that frequency a bit…
Cool fix. Pun intended. I would like to put something like this on the space’s kiln, could you point me in the right direction? Thanks,
Eris.
