It’d be really nice to have a properly nice lathe with all the trimmings and the new green lathe is a perfect base for that. @Boo has some tricky stuff to do on it, so I said I’d find all the bits to make life easy for his project. I recently got access to a DRO lathe, the space needs this. Lathe DRO is Jesus.
Basically, all that lathe needs to be exactly what we need, is mist coolant, DRO and a quick change tool post. So my suggestions are as follows.
We can put them on the other machines as well, and have a spare or two for later or dual nozzles for something like the mill.
Theres lots of options for the DRO kit. Can be cheap, or not.
Basically ranges from;
http://www.machineryhouse.com.au/Digital-Scale-with-Display-Units
1 x 300mm scale - $55
1 x 1000mm scale - $115
1 x Display - $115
Total - $285
To;
1x 300mm Scale - http://www.machineryhouse.com.au/Easson-Scales - $240
1x 1000mm Scale - http://www.machineryhouse.com.au/Easson-Scales - $320
Display - http://www.machineryhouse.com.au/Digital-Readouts-Easson - $550
Im sure theres advantages to the more expensive options, but I dont really see the need, but maybe someone with more time and inclination can find a better " bang for buck" option somewhere in the middle.
Then the quick change tool post, the tool post that is on the machine is grand, I’d be perfectlyhappy with it, but I know it will frustrate the new gamers. Its a process to set up a tool on the current post, with shims and spacers etc. and I think we can get something that can utilise the tool holders we have for the current grey lathe.
I think that will do the job, would need to confirm that, but I think its compatible with the green lathe, and the tool holders we currently have. again, a little more research is needed, there may be a better option somewhere.
http://www.machineryhouse.com.au/L292 - $187
Overall, I think with the addition of these 3 things, spending between $400 and $800, our new lathe can be a really user friendly and robust piece of gear.
EDIT: Ive been away a lot over the last month or so, but Ill be around on a more regular schedule in about a week and a half, and can install all these things then if we decide to go ahead with it all.
