I have made this forum entry as a knowledge and news base for the new CNC in metalworking.
Now that the new machine is here and the mechanical functions have been tested the unit is (was) ready for programming/interfacing.
The software and manuals are under “metalworking” section of the library.
We need to come up with a name. I was thinking “Heidi” as it’s a German name (Siemens is a German company) or “Billy” (so we can name the manual mill “Millie”, suggestions welcome.
Since last Tuesday somebody has changed the tool out. I am in the process of setting all the tools specifically in their assigned arbors and at specific depths. So feel free to swap entire cones out but ~please~ don’t change or adjust what is in each arbour holder as they are mapped by the machine.
I discovered today that the roof above “Billy” leaks a bit, I will endeavor to make a tent at some point, its only dripping into the wet areas of the machine anyway.
The machine has changed itself to Chinese and has error 700000 since last week, I am hoping this is something to do with the wet weather. Does anybody read Mandarin here? https://support.industry.siemens.com/tf//WW/en/posts/after-tried-to-turn-machine-on-got-fault-700000/179848?page=0&pageSize=10
justpastpluto@gmail.com has invited you to comment on the following document:
Using the metalshop CNC “Hildi” pre-wiki
Link to view CNC instructions
This email grants access to this item without logging in. Only forward it to people you trust.
Google Docs: Create and edit documents online.
Google LLC, 1600 Amphitheatre Parkway, Mountain View, CA 94043, USA
You have received this email because justpastpluto@gmail.comshared a document with you from Google Docs. ![]()
Thanks again for working on this! When there’s a bit more, would you like me to do this all up into a wiki page, and link it under metalshop?
Yeah that would be awesome. We are using it as a working doc at the moment. I will add some pictures etc once we are done. At least there’s a workflow now, I’m going to try it on actual metal next visit.
