1 x Pcduino3 Nano without Wireless
1 x Arduino ATMega 2560
1 x 4 Port Usb Hub
2 x Microsoft Life Cam
1 x Usb Wifi Module
8 x Lithium Batteries
1 x Adafruit Arduino Motor Shield
2 x APC220 serial wireless modules
1 x Arduino Nano
2 x MPU6050 GY521
4 Tyres
4 DC Motors
2 x 20W Buck Converter Regulators Variable
1 x 5V UpConverer
1 x 8Gb SD card
Pcduino Operating System
Armbian for Pcduino 3.4 linux kernel for the A20 Allwinner ARM processor with Mali GPU drivers.
With the Armbian operating system I was able to activate accelerated Opengl Graphics. I installed the x11vnc server which uses the X11 server to send Opengl accelerated Graphics. Using turboVnc as the client. I also installed ARToolkit5 from Github for the ARM processor.
Each ARMarker produces a Matrix from which the distance can be calculated. With two distances and the location of the markers known the Intersection of two circles is calculated from the equation obtained from StackExchange:
The equation is a simultaneous equation with two answers.
From this the x and z position was calculated. Z being into the screen and x left of the screen. Y up was omitted.
X=329.72 and Z=144.46 millimeters.
This project is on-going and I will post updates as they happen.
Comments welcome.
I helped (a little) with an AR drone demo at the Switch On demoparty last weekend (using artoolkit through AR.js I think); the markers used definitely weren’t square It was using the NFT feature.
Doesn’t have a camera on it at the moment, mostly because I’m concentrating on LIDAR and extracting wall and corner features from that. Also, my every attempt to compile OpenCV on a pi has been… disappointing.
ARToolkit looks like a much better fit for robotics anyway!
Thanks for sharing.
I found it was much better to set up an emulated Raspbian container on my PC (using QEMU, binfmt and chroot) and compiling it in there - it’s blazingly fast and avoids all the hassle of getting cross-compiling working.
I haven’t got that far yet. But I have some ideas about improving the process and dropping the need for the ARmarkers. My idea is too increase the number of camera’s from two to four so the rover can see all around itself. At this stage I want the rover to generate approximate spatial coordinates. Object avoidance is another issue.
I dont use openCV 3 because of issues with the compatibility. I use openCV 2.4 I believe. I haven’t had any compile problems but I use Armbian on the Pcduino.
@Svenska and @ian.kerr.redmond That repo has been strangely popular - I only put it on GitHub so I could easily get it to my raspberry pi’s at the time as I had to keep reimaging them and got sick of waiting to rebuild it each time. I don’t recommend it as it’s broken with the newest raspbian releases. (I haven’t updated it)
Funnily enough I’ve even had a few academics email me asking me to update it as they were using it for their university classes but it doesn’t work on the newest raspbian.
