Did a stocktake this evening with the help of @Ale and @zach.forrester, results as below. This list should be used to determine a restock budget.
Sandpaper
- Belt 150x1220mm @P120 12/20 60%
- Disc 305mm @P120 29/40 72.5%
- Disc 305mm @P100 6/# NA%
- Disc 610mm @P120 10/10 100% (Machine still being worked on)
- Bobbins
- 6mm @P120 7/10 70%
- 12mm @P120 7/10 70%
- 16mm @P120 9/10 90%
- 38mm @P120 6/10 60%
- 50mm @P120 4/6 65%
- Roll 79mm /25m 20%
@P240
- 1630mm
- 1850mm
- ~5.5m
- @P120 0/25m 0%
@P240
- Roll 93mm /25m 35%
- P120 7.6m / 25m
- P80 11.5m / # NA%
Blades
Bandsaws
- N4400
- 12mm @ 4TPI
- 25mm @ 4TPI
- BP250
- No blades
Other
- Scroll Saw
- One standard blade in machine, no spares found
- Handheld Jigsaws
- 5" 10TPI 2.5mm, 3/# NA%
Fasteners
- Screws, Robertson Drive
- 16mm ~10k
- 22mm ~10k
- 28mm ~10k
- Other: uncounted
- Brads
- 15mm, 25mm, 32mm Low/Out of Stock
Glues
- PVA
- Out of Stock
- Gluebots
- All out of commission
Bits
Drills
- Brad Point Drills
- 0-2 of each size. Sold in sets of 7, 5 packs to get back to spec.
- Jobber drill bits currently not stocked
Drivers
- Phillips @25mm <10
- Posidrive @25mm <10
- Hexdrive @25mm <10
- Robertson/Square @25mm <10
General Chemicals
- CMT Blade Cleaner - Out of Stock
- Rust Converter 3/4L
- Vinegar 6L
- Silverglide rust inhibitor, 1 container
- Felder surface protector, >50% of bottle
