Now V 5.02
(Simplify3D Release Notes)
Version 5.0.2
- New statistics in the Machine Control Panel monitor total print time and estimated time remaining
- Hover your mouse over the remaining print time to see the calendar date and time when the print will be completed
- Preview Mode can now be automatically exited by importing a new 3D model, factory file, or build file
- Improved toolpath placement for specialized builds using zero outline perimeters
- Expanded international character support for 3D model files and printer build files
- The build volume displayed in the 3D view will now always match the first process in the list
- USB printing for x3g machines has been improved with reduced latency for densely meshed files
- Updated USB support for SD card setups that require manual initialization
- FlashForge machines can now list files directly from the internal storage using WiFi or Ethernet communication
- Added WiFi and Ethernet communication support for MakerBot Method and Method X printers
- Improved scrolling for the Machine Control Panel communication log during periods of high activity
- Expanded licensing support for a wider variety of computing environments
- Fixed a bug that could cause a crash when loading new factory files after specific model operations in the UI
- Fixed a bug that could create incorrect support structure bounding dimensions
- Several additional bug fixes and stability improvements
- Added support for 8 new 3D printers including the Anycubic Kobra Neo, Anycubic Kobra Plus, Creality Ender 2 Pro, Creality Ender 5 S1, Creality Sermoon D1, Elegoo Neptune 3, and Raise3D Pro3
