This is a brief how too
for those inducted on Sven Hanzka’s green and orange(lights) cnc in the wood working room.
Preparing your files
- Import stl from cad or thingyverse into Cut3D or Freemill or similar
- Set units to mm’s
- Orient model home position
- Add material dimentions
- Set speed and feed rates (conservative) [we used 2mm depth 120mm/min with our 3mm cutter]
- Check tool path settings
- Post Processor settings[ G Code mm (*.tap) ]
- Look at the estimated time and weep
The Machine/Computer
- Password is the same as the wifi
- Put your gcode on the desktop (because usb wiggs out sometimes mid route)
- Open program “Universal G Code Sender”
- Set home position on material manually [be sure to remember the orientation of your material in cad and that the y axis is backwards]
- Spool up the motor
- Hover hand over kill switch and click ‘Go’
Success !
Remember this machine is capable of self destricution and personal injury. End mill (fancy drill bit) not supplied. Please only use if inducted. Talk to @Svenska or @Hally or any awesome member to find out how.
