Continuing the discussion from Dashy:
@theban I’m currently rewriting our spaceapi endpoint code to be universal for all hackerspaces, by turning it into a CRUD API that anyone can submit data to, provided the data is in the spaceapi spec ( http://spaceapi.net/ for deets).
It’ll have a json endpoint for spaceapi to pull from and a config endpoint for the static data required to be set (Hackerspace name, location, etc).
Current code is at GitHub - nog3/hsbne-spaceapi: HSBNE Spaceapi endpoint, also mqtt broker for sensors at HSBNE. but I’ll probably be forking the rewrite into its own repo ![]()
