The Big Blue Boyscout: Jimmy's Arcade machine
First off, huge shoutout Arcadeworx and DIY Arcade for the wood and electronics respectively.
So this is what we started with:
As you can see, it’s essentially a piece of IKEA furniture. I took it home and with some help from my sister we got THIS far:
Enter Hackerspace where we broke out the airguns and the hydrolic lines and we did this to it
SO we have it primed and ready to go with the BLUE colour scheme which was finally done last night
Next steps are Perspex at the front and in the marquee, attaching the S logo and the electronics getting inserted.
Stay tuned
Ok so, we ran into a few issues that nearly turned into disasters but with a little inginuity we were able to move forward.
The first thing a few of you probably noticed is that there was no room to get into the console, meaning attaching the joysticks was near impossible. SOOOOOO:
I took out the front parts beneath the arcade. This let me get in underneath and attach not only the joysticks but also the microswitches:
Everything has a nice clicky sound and feel now. and from the top looks pretty good too…
After some forcing and rewiring I also added in a coin acceptor:
Finally, because I had some time on my hands, I painted the S that’s going on the front
I can TASTE the end of this project
So we got it working
Huge shoutout to mah boy Dan who helped A LOT through this project. We’re nearly done!
Ok so we’ve gotten A LOT done over the last little while. Check this out:
With Meka’s help cutting and Dan armed with the drill, we mounted the S to some perspex. I look cute like this!
received_10160531616125319%5B1%5D|375x500
The next step was pretty easy, attach it to the cabinet. (and put the parts we took off to access the joysticks back on. After mouting the amplifier)
We’ve also attached the screen. Here’s Dan playing the very japanese and a LITTLE racist Fancy World:
As you can probably tell I’m pretty excited to be nearly done. Here’s a video of every part of the machine working. Just have to fix a few cosmetic things and physically mount the speakers and what better way to test them than Micheal Jackson’t Moonwalker?
