We are selling this machine we got through a donation. Is a nice little machine, seems to work fine and I reckon a little bit of TLC will do the trick.
Some knobs are broken, but still all the adjustments can be done.
The previous owner fitted the jointer tables to hinge on the opposite side (i think to save on space) but this can be changed back.
This machine is the same that carbatec sells.
We are asking $900 to HSBNE members for it ($1200 everywhere else).
SPECS
| Cutter Type | 3 Knife HSS |
| Cutterblock Diameter | 70 mm |
| Cutterblock Speed | 4,800 rpm |
| Dust Extraction Outlet | 100 mm |
| Feed Speed | 5 m/min |
| Length of Table | 1,100 mm |
| Max Depth of Cut Planer | 3.0 mm |
| Max Depth of Cut Thicknesser | 2.0 mm |
| Max Planing Width | 260 mm |
| Max Thicknessing Capacity | 190 mm |
| Min Extraction Airflow Required | 1,000 m³/hr |
| Nett Weight | 182 kg |
| Number of Knives | 3 |
| Overall L x W x H | 1,100 mm x 660 mm x 940 mm |
| Plug Fitted | UK 16A Plug |
| Power | 2.2 kW |
| Rating | Trade |
| Sound Power Level LwA [Uncertainty K] | 89 dB(A) [1.5 dB] |
| Voltage | 230 V |
