Hi all,
Just a thought… I’ve currently got my eye on the Kite phone project, which is a 4G phone delivered as a build-it-yourself kit. The kickstarter project isn’t live yet, but there’s a draft of it here.
Crucially, it comes without a case, you 3D print that yourself.
Right now I’ve got a ZTE T83, and @vk4mdl gets by with the slightly newer T84. My phone largely works, but is stuck at Android 4.1, which is getting a bit long in the tooth now, some of the software on fdroid.org is now seemingly for Android 5 or later, so I see supporting this OS is going to get harder moving forward.
The T84 @vk4mdl has is better in that it runs Android 5 and has higher specs, but there’s a catch: its cellular transceiver performance is rubbish compared to the T83. We just did a trip down to the Snowy Mountains, and there were times I was holding both phones in my hand, my phone would report a strong 4-bar or better 3G signal, his would report “limited service - emergency calls only”, or worse, “no network coverage”. External antenna made no difference in these cases.
Looking in the Telstra shop today, the staff there couldn’t explain the discrepancy, and I noted none of their current crop feature the external antenna connectors of these two devices.
Thus, we’re both looking at the Kite. We can 3D print cases for these, but then I thought, there’s an injection moulder here, why not use that? Especially if a few others are interested, we could put an order in for a couple, and injection-mold a few cases in one go.
What’s the steps involved in producing a design to be used with the injection molding equipment?
