So what are we trying to do ?(aka scope):
Basic : Make a mini weather station at home and learn something doing it.
Delux: Make a mini weather station network that you can see all the changes in micro-climates around the area. We can send all the info to a mini sever that we can all see!
Whats involved?
Bit of soldering, bit of programming, bit of this, a bit of that.
Im keen on having a network of these things setup so we can spy on each others local weather! But have no clue about internet - networking or sever programming.
If you are willing to learn come chip in!
Sensor selection
what are we going to measure, let’s keep it basic at the start, so I vote:
Temp
Humidity & Temp
Pressure
With the provision to add more fancy-dancy sensors later, like ohhh UV, wind, etc etc.
Controller Selection
My first go-to would be a Raspberry Pi, I have never played aound with them, but have always wanted to. They are powerfull machines with WiFi options and SPI, so we can add things like this (Thanks @Hally).
Other pro’s: They can store a heap of local data, and host their own severs, so if we wanted to get fancy we could have a syncronised network with no master sever, but maybe something a little less complex first ha.
They are also nice to have around the house for other gizmos and thingys that you want to add on-to later.
How we gona do this?
To avoid the dreaded 60% finshed project, divie this thing up into little bite sized chucks that we can all nibble on when we have a bit of down time, an hour a here, a couple there.
So what should I do?
That depends on a few things, what can you do? What things do you want to learn? Ill have a nibble list ™ up soon.
But most likely you will want to start getting to know what is a micro-controller, Ardunio is a good place to start. And having a look at some basic raspberry pi projects (maybe setting up a Raspbery Pi sever…) couldnt go astray either!
I can help people do the basics of controllers, and soldering. If some one knows their way around setting up serves and internet protocalls, let me know!
Jace
@Wixted
@erisryan2 @Eris_bureau_of_strif
@nogthree
@Hally
@Robert_Denney
