Howdy All,
I’ve been playing with some electronics this week for our project 12 Tone, for VIVID Sydney this year. In essence, its a bunch of lights in some chunks of wood. It’ll be pretty, eventually…
I’ve come to an impasse with the XBEE Modules and any guidance on the subject would be fantastically appreciated.
End Goal:
We would like to transmit MIDI data from a central point, out to all the individual stacks as pictured;
The current situation:
I’ve spent this week making these things talk and generally familiarising myself with their ins and outs so I can actually ask meaningful questions and getting something from the suggestions. As far as I can tell, these modules will do what we’re asking of them.
I wrote a little bit of code using some examples @capella_ben1 sent me. Its basically one teensy reading a pot and blinking a pot according to that value, and forwarding that value over serial to the second teensy running the same blink program.
Heres my code;
If I send the serial over a hardwired serial connection, it performs as intended. No lost packets, no latency issues.
One the XBEEs enter the equation though, things get all weird.
The specifics of the modules;
Product: XB24C
Function Set: ZIGBEE TH Reg
Firmware: 405F
These are the profiles I’ve set up according to various internet resources;
The Problem:
Theres at best maybe 500ms latency, and at worst, maybe 20sec. I don’t know if they’re sleeping, or theres some buffer fuckery going on, I just dont understand enough to meaningfully diagnose the problem. I can send from the sender, and receive at the receiver, but something doesn’t quite talk properly.
XCTU is the configuration platform for XBEE. Its got a terminal. You can open a couple of instances of XCTU and send various packets etc back and forth. This is the best test Ive been able to really perform.
XCTU lets you create a packet, whatever size you like, and shoot it over at set time intervals. Looking at some MIDI documentation, it seems to me like most things can be done in a 10 byte packet. So I sent 10 byte packets, 20 times at various intervals and watched.
@2000ms - No packet loss or latency issue
@1500ms - ~1 lost packet, receiver hitting some kind of issue around the 10th transmission
@1000ms - ~3 lost packets, same issue as above, but a little earlier, maybe the 8th or 9th
@750ms - ~6 lost packets, starting at the 8th
During redoing these tests and writing it all down, I got curious what the connection was like from router>coordinator, the reverse direction of what I need. Its absolutely flawless. 10 byte packets, every 1ms, 0 out of 500 packets lost. Same conditions Coordinator> Router (The way I want to go), it falls over after about 70 packets.
Questions
Can you think of specific packets I should send?
Any thoughts on buffers?
Any thoughts on timeouts?
Any thoughts on a sleeping module?
Appreciate any advice anyone can provide. If theres any info you’d like to see, I can provide.
Thanks all.
