ZCorp Powder Printer Thread
Hey Team,
We officially have a donation of a ZCorporation ZPrinter 310+ Model, which is a powder-based 3D printer will full colour capability. It can also print with Z-Cast and Investment Casting powder for creating aluminium casting moulds. You can also by elastomer powder. Currently it is sitting in the boiler room until a more permanent home is found.
  • This machine was donated by Darren, who picked up the machine at an auction for cheap as it was hidden with a lot of other equipment and not recognised for what it was. The printer is about the size of a large photocopier, has wheels, weighs about 200kg and comes with a separate 400mm x 400 mm x 1.6mm de-powdering station for removing and recycling excess powder.
  • During the auction process, the machine had been tipped on it’s side and the powder had solidified. Darren has already done much of the cleaning to fix this up.
  • The computer doesn’t boot. Darren was quoted $5700 for probably only $400 worth of parts from 3D systems to replace the electronics.
  • Carriage bearings need replacing as they got powdered
  • The powdering station compressor may need replacing, the pressure switch also trips.
  • Powder can be recycled and is not wasted. @capella_ben1 has pointed out we can make our own powder and binder with the wealth of info on here, even made out of sugar and vodka!
    http://reprap.org/wiki/Powder_Printer_Recipes
    http://www.evillabs.net/index.php/ZCorp_Z310%2B
@DreadPirateRobinson can fill in any more info I’ve missed
@jabelone is currently working on booting the computer
Unfortunately the controller PC complains about not seeing the PCI controller card when it starts up.
On inspection it was discovered that the PCI card has a big bend in it (!!!), and as a result a lot of the pins on the main fpga chip have broken off from their pads. I’ve put the bent edge in a vise and am trying to take some of the bend out before I resolder the chip. No idea if that’s the only problem or if there are more broken traces than the ones I can see directly.
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
Another open source powder printer - http://ytec3d.com/plan-b-building/
Wish you success
