Rule changes for Lasercutter
the laser cutter can only be run under the supervistion of a laser saftey officer (key holders)
the key holders are to be voted on by the cause current standing for key holders for laser cutter is Mike, james, Nog and Aaron
if you run the lasercutter without one of the Key holders in attendance at the hackerspace (supervising), a ban will suggested to the exec for 3 days.
Iād like to add these items for discussion:
I do not think it reasonable to limit those who can operate/supervise the laser cutter ( called ākeyholdersā by crofty in the previous post) without their being a clear set of criteria for how others ( non-key-holders) can become ākeyholdersā. I expect this would be a set of demonstrable skills that can be gained under supervision, and a willingness to remain updated on regular changes/tweaks to the system through close contact with the other keyholders.
Proposal 1:
Iād like to vote on having the following as the steps that need to be taken to become a ālaser supervisorā ( if someone wants to write up a longer or more detailed list, no problem, but this is a good start):
1 - first time using the machine, get shown how its done, by a current āsupervisorā, as a spectator only, no touching the machine, but ask as many Qs as you like about the process. ( this is upskilling on the process, and proper/normal working )
2 - second time using the machine, you may operate the machine directly while 100% āsupervisedā by a current supervisor. , including cleaning. If you are able to demonstrate operating the machine from beginning to end without error, you may proceed to next step. ( this is demonstration of the skills )
3 - third time using the machine, also fully supervised, the supervisor should deliberately introduce a āunknownā fault in a secondary piece of equipment ( eg disable the air compressor ), and the new operator must be able to identify and fix this minor fault without causing equipment damage etc. (this is upskilling on possible/common faults, and how to identify )
4 - the new supervisor is required to join the laser-supervisor/s preferred communication/s channel ( eg slack?), and keep up-to-date on issues/faults/rectifications, including being involved in repair of issues where itās within their skillset and time abilities.
5 - the new āsupervisorā is now permitted to operate/supervise the laser without other supervisor/s present.
6 - the new person is added to the wiki page as a ālaser supervisorā.
For example, I note that I have done the equivalent of the first 5 steps already, as far as Iām aware, so I expect that I would be able to become a proiperly sanctioned āsupervisorā after this relatively easily.
Proposal 2:
Proposal to accept Buzz as a āsuspervisorā for the laser cutter subject to him satisfying the above 6 points to the satisfaction of at least one current supervisor.
Itās not that weāre special or anything, itās just that weāre actively working on it. Getting āapprovedā just so you donāt get slightly inconvenienced when using the machine is precisely the sort of thing we donāt want.
Also, inventing a process so that people can pretend to be āactively working on the machineā just so they can get āapprovedā so they can avoid being slightly inconvenienced? Fuuuuuuck that.
Hell, maybe I should stop getting in the way. When the laser cutter dies, it wonāt get fixed, and we wonāt have to have this argument again.
And Buzz, YOU HAVE YOUR OWN MACHINE. If youāre motivated to fix ours, thereās no reason you canāt have yours working.
James, you post appears to be filled with emotion, which Iām going to ignore.
My concerns are first and foremost that I want a clear and precise method that people can use to become self-sufficient with the equipment, so it can be used by members who want to use it, not at the whim of the the few who have previously been able to commit large hours to that specific machine.
Also, with regard to the myself specifically ( not the most important point, see above ) , are you saying Iām not adequately trained to use the red laser cutter unsupervised (capabilities), or are you saying Iām not adequately āengagedā with the nuance/s of the laser cutter(troubleshooting) ?
I m not saying that key holders are set to those people and just those people,
I m saying that those people are the ones that are trusted to run the machine at this time and those are set to be the first set of key holders.
Others to be added later once it can be shown that they can handle the machine and are willing to spend a little TLC on the machine.
At this point the 4 people that are able to use the machine are the ones spending the most time fixing it and gettting it back to working order all the time.
Because we keep trusting people to use the machine under supervision and we have having to clean the machine after use.
Guide lines are being broken all the time with the machine by people that are trusted to run the machine under supervision and it is getting really bloody annoying having to always watch out for people screwing with it, ie the machine is not to be run when the temp gets above 30c, if it does get that high cool the room down then use the machine again,
I would just like to point out the reason that the Red one took so long to get repaired was because we were waiting on parts in china to be fixed under warranty (which did not end up happening) and as well as waiting on a new smoothie board, once this had happen would would have notice the Nog and I kicked our ass into gear to get it back online for use.
We then had a safety audit which Mike (for good Reason) pushed all those that we working on the laser cutter to read the safety standards and get the machine in compliance.
Mike then with help from Nog, myself and a few others cleaned the lens and mirrors, something in which in the past, were cleaned with a shirt.
and the tool chain is always being worked on by James all the time.
Iām not trying to appoint blame, and really, I donāt care much as to WHY it was offline for so long⦠Iām just pointout out the fact that it was, and that I felt by having two laser cutter/s would mean weād be more likely to have one that worked. ( and that in fact turned out true, as the red one has been mostly working most of the time due to the effort/s of many ) .
Folks, can we please not read tone and emotion into peopleās messages. We all know text doesnāt accurately convey that and can lead us off track.
Buzz, I donāt think your process is completely unreasonable and sounds like a decent framework to work from in future once the machine is more reliable.
Neither. Your primary goal is to use it for your own projects. Thatās fine, but it means youāre only going to pay attention to the machine when youāve got a personal need for it. Weāve got four people who are actively maintaining the machine so that the machine is available to you. We bend over backwards to be around when people ask to use the machine, and multiple people have had no problem getting dozens of hours of laser time under this arrangement.
When people who havenāt even asked for our help start going to lengths to justify why they should be allowed to use the machine alone, thatās a major red flag.
Finally, weāve had trouble keeping everyone up to date even when thereās only four of us and weāre all paying attention. Add in a dozen random members who are purely focussed on getting their own project done? Thatās a recipe for disaster.
James, your assertion that I will be unwilling to assist others by supervising them is incorrect. I have done little of that so far purely because Iām not a sanctioned supervisor of this equipment, and till today had no clear way of becoming one.
Had a talk with Adam privately last night, and a few points came out of that conversation.
Weāre not supervising the users. Weāre watching the machine itself, so that we can address any issues that come up when youāre trying to use it.
You donāt need an induction to be allowed to use the machine, but one of us has to be around and given permission every time. If weāre comfortable with you using the machine, and the machine is in a reasonable state, we probably wonāt do more than poke our head in occasionally. Thatās not a major burden, and weāll happily negotiate to be around when itās convenient for you.
There is no induction that gets you to the point where you can maintain the machine yourself. We donāt need or want more people fiddling with the machine, four is already too many.
If you really want to play with a laser cutter for the sake of it, thereās a whole second laser cutter in digifab that needs a lot of work to be done on it. I daresay Aaron would accept any that is offered.
Iād also like to add 3D printing inductions to the agenda for mentioning.
Next year Iām really keen to begin teaching the basics of 3D printing, including a how-to in using the machines. Iāve recently run 3D printing workshops at the Coterie (QUT) and my theory content is up to date. Iāve also booked myself in to do a more consumer-focussed version of the content with Brisbane Workshop here: http://www.work-shop.com.au/event/intro-3d-printing/
It would be great if you could ask at the meeting for volunteers to sit down with me on a convenient Tuesday night/weekend to flesh out the wiki page around this more to include the āhow-toā. http://wiki.hsbne.org/tools/repraps
This means I can start to translate this into my existing presentation. Alternatively, volunteers that are also willing to start to work on the wiki documentation in their own time are also great.
Iāll also look at pairing the 3D printing workshop with a 3D modelling workshop to run one after the other. This also means digifab can start to hit the class quota.
As a side note, I think monthly ā3D modellingā meetups might be cool. Just work on your own stuff and ask for help if you need. Iāll look into doing this too if the 3D modelling workshop is popular.
I have not seen the outcome of this digifab meeting ( minutes etc ), so I presume that because it was scheduled for the day after boxing day , during holiday period that it was either cancelled, or postponed?
