Hi, I’ve checked Timbecon to see if something caught my interest. Here’s a list of the things I think could be beneficial for the space. Keep in mind that timbecon for some products is quite expensive, but anyway here we go.
Torquata Flat-Top Dado Saw Blades
6mm kerf. The arbor or our saw is not long enough to support a dado set, but this blade is cheap and we could make some jigs around it, like a box joint jig or such.
https://www.timbecon.com.au/torquata-flat-top-dado-saw-blades
Table Saw Fence Aftermarket Complete Assembly
I think it would be nice to have a better fence system, that is quicker and more reliable.
This is a biesemeyer style fence, i think we would spend the same money by making it out self.
https://www.timbecon.com.au/table-saw-fence-aftermarket-complete-assembly
iGaging EZ-View Pro Digital Read Out Scales
This with the previous one would make our saw more precise, reliable, with less hassle and error.
The only downside of this is that we would be loosing a littlebit of ripping meassured capacity.
https://www.timbecon.com.au/igaging-ez-view-pro-digital-read-out-scales
Micro Jig GRR-Ripper Advanced Control System
Because safety first, good ol’ grripper.
https://www.timbecon.com.au/micro-jig-grr-ripper-advanced-control-system
Torquata Router Bit Tidies Organiser
I would get a couple of this, they are cheap enough to not bother printing them and we need to get those router bits in order.
https://www.timbecon.com.au/torquata-router-bit-tidies-organiser
Milescraft Sub-Fence Clamp Brackets
These were already pointed out by Josh. They will reduce setup time in the table saw drastically.
https://www.timbecon.com.au/milescraft-sub-fence-clamp-brackets
Incra V120 Mitre Guide
No hassle with this mitre gauge, acurate cuts with minimun setup. Adding and aluminum fence to this makes it a beast.
https://www.timbecon.com.au/incra-v120-mitre-guide
Sherwood Dust Extractor Vacuum Head Adaptor
I would get at least one of these to help keeping the shop tidy.
https://www.timbecon.com.au/sherwood-dust-extractor-vacuum-head-adaptor
Dust Extractor Floor Vacuum Kit
This one comes with the previous one, and brings the giant wand to clean the floor and the floor sweep head. Quite handy.
https://www.timbecon.com.au/dust-extractor-floor-vacuum-kit
Hold Tite Hose Extraction Kits
I would get one of these on the 63mm version for the drill press.
https://www.timbecon.com.au/hold-tite-hose-extraction-kits
